P-Delta Analysis In Etabs
Sohaib Iqbal
Respected Engineers. while doing P-Delta analysis it gives two options:
a- non-iterative based on mass
b-Iterative-Based on load combinations
what is the difference between them and use of them?
how to calculate iterations and which load combination we use when using 2nd option?
  • 5 months later...
dear uzair i had chekd ur attachment regarding p-delta analysis parameters.to some extent it is informative but in that it is not mentioned that for p-delta what  load combinations we shud take. instead it is referred to chek download ETABS VERSION 7 MANUAL but in that manual too i was unable to find the required load combos n scale factors.that was for ur kind info.
Dear all.
Most of us must be knowing that etabs works on the structural analysis method of FINITE ELEMENT METHOD. This method is taught at Masters level under a separate subject under above mentioned name bt wat abt those engineers who r practising after bachelors n even better exerienced at design. But they definitely hvnt complete idea as to how etabs performs the analytical process. Can some1 refer any precise n brief material to understnd the FEM?
THNX
