Steel Structure Design Competition
hussainm
I am working on a project where we are looking to build a 7 bay shed with 30m Span each bay and length of 100m. Now the feedback I got from some chinese engineers was that the standard design in china is either 24m or 27m or 30m, with columns at every 9 meter. So I am looking for some help in choosing between either of the 3 spans. I will be running 2 20 Tons capacity double girder cranes in each bay.  In the future we will double the length of each bay so does that also play a part in span selection ?.
Also the steel grades we can easily source are either SS400, a36, or s355 or q345. Does the grade of the material help in weight reduction and if so how much percentage, so we can compare.
Few details I have regarding the crane is
if 24m span, the total weight of the crane is 29 tons (including all components)
if 27m span the total weight of the crane is 33 tons
if 30m span the total weight of the crane is 38 tons
There will be lot more inputs you may need from my side so you can post here and I will try to answer quickly.
The lightest shed design and model will be awarded with a cash reward and a job offer based in Karachi. We are not a designing firm, we are the end user of this shed.
Dear hussainm,
In general, larger the frame span or bay spacing, heavier will be the structural members. Morever, higher the yield strength of steel (e.g., 50 ksi), lighter will be the members, when compared to members made of lower yield strength (e.g., 36 ksi for a36) steel.
Since you are not designer, it would be better to advertise your requirements (required shed size & height, No. & capacity of cranes, and most economical design etc.) in a few high-circulation newspapers, asking for design proposals from the specialist firms having experience of design & construction of such sheds. In this way, you may get more than one design proposals to select the one that not only best suits your needs, but is economical as well.
You can send me the drawings. I can design it for you with ten years warranty. We are using same software as are used by Zamil and Mabani. I ensure you to provide most economical and safe design. You can contact me on my no. +971 555 469 987 or at my email nauman.mukhtar@hotmail.com.
  • 11 months later...
On 3/14/2016 at 11:49 PM, UmarMakhzumi said:
Warranty should be equal to or more than the design life of structure, which is 50 years as per most building codes.
Dear Umar!
Can you refer to the specific sections of different building codes, along with Design Life indicated therein?
  • 2 years later...
Hello, can I request for a copy of reference for pre-engineered building?
Asak
Please upload the Drawings and share the link
All the participants  will submit the proposals
and then you can choose some body and can finalize the system
also u can announce the winner & his proposal
regards
