How to solve bending moment probelm ETABS
Alinalysis
Hi Alinalysis,
There might a reason for why you are getting such moment distribution. Please share your model and someone with ETABS might be able to help it out.
Regarding 2, Yes you can do that. I normally provide hanger bars when one beam is supported over another and I release the moment for the end that is supported (that would be end of beam 1 supported on beam 2).
2 hours ago, UmarMakhzumi said:
Hi Alinalysis,
What do you mean by hanger bar?
Can you explain it, I only released the moment but that didn't help
etabs file is attached
sample.rar
11 hours ago, UmarMakhzumi said:
Please see the image below for hanger bars. I don't have ETABS. I do have SAP2000 so I can't check your file. Is your beam failing?
54307684-beamcolumn-17-728.jpg?cb=134546
hi
My beam is not failing I just run the analysis without designing yet
Etabs and sap I think have similar modeling technique, so can you please tell me how to set a beam as a support for another beam in the software, is it only releasing the support? I did that but the reaction is in the opposite direction
Hello
I figured out the way to support a beam over support
I will show this figure as example
2.png.5928b0b57fcaf2a67b92b82d8c759dde.p
Only have to Split beam 2 at intersection with beam 1 and the beam 2 will act as a support for the beam 1 at that point
Now  I need to figure out why the bending moment diagram is acting like that
May i ask another question : I assumed that all beam-column end connection are pinned, how can I design the column for bending moment at the ends?
I am not sure about your questions.
Anyway, If you split the beam, make sure beam 2 is continuous. Like I said before, your beam 1 end would be pinned. Also, you can use snap tools to connect beam 1 at beam 2 location without splitting it.
If your beam column connection is pinned, then you will have no bending moment. If you design to provide a moment connection, you will have to change that in your model. You decide what you want and you tweak your model accordingly.
OK so I have to change the model
Thank you for your help;)
2 hours ago, Alinalysis said:
Hi all
I managed to solve the problem for most the beams by modifying the torsion factor and set it to be 0
However, still some beams are having the same shape of moment
For torsion modification factors and its use, please see the link below. You will have to detail your beam Beam 1 without any negative moment so that it produces no torsion in Beam 2. Like I said, I don't have access to ETABS so I can't check why your moments are the way they are.
Hi Omar thank you for yours post
I solved the problem by modifying the torsion factor as well as removing the stairs and ramps from model (Any way we will do it manually)
your link will be helpful
I don't know whether I should design the beam for torsion or not, I had two courses in concrete design but never been taught about this topic:(
You are welcome.
Before deciding whether to ignore torsion or include torsion in the design, you need to understand if it is compatibility torsion or equilibrium torsion. For your case above, you can justify ignoring torsion by not providing any negative reinforcement at the end of Beam 1 that is supported on Beam 2. To understand the differences between the two kinds of Torsion, please read the following article.
Thanks a lot.
On 3/17/2016 at 1:16 AM, UmarMakhzumi said:
You are welcome.
Thanks a lot.
Thank you I asked my professor and I will consider the torsion as the program will calculate the required reinforcement
