Best way to model concentrated load
WR1
If there is a concentrated point load in the middle of a two way slab. What is the best way to take out realistic results. Also what would be the best judgment to calculate strip width.
As you know, the size of the stress contour and its magnitude depend on the mesh size too. So what would be the realistic value to use.
It depends what is the source of the load.
For example if the concentrated load is due to an equipment, the realistic basis would be to see the footprint of the equipment and divide the load over that area.
The question about strip width is always tricky. Certain firms have their own design preferences too and its varies a lot from firm to firm. I normally discuss this with my checker of If I am the checker I discuss it with the engineer and we both agree to some common interpretation. Ask you checker/ engineer and agree upon something.
I wouldn't get stresses over size of mesh. Reasonable size mesh (that doesn't hurt your analysis time) would provide conservative results. The finer your mesh gets, the finer the stress contours become (because of better stress averaging). You can do some sensitivity runs to be more confident on what to use.
Edited by UmarMakhzumi
For the last point, I would like to add that stress would go on higher and higher if you keep refining your mesh due to introduction of singularities in the solution at corners and under point load. So at what level you would stop doing the refinement. Yes the sensitivity analysis is performed to compare mesh refinements but for this particular case what would be the basis? deflection under point load?
Normally sensitivity analysis is done till you hit convergence; that is any further mesh refinement doesn't increases the result by an acceptable margin. That margin is again dependent on firm practice, local experience and judgement.
It is true that stress would go higher as you refine your mesh but also the circle would become smaller and smaller. If your stresses are within 5-10% of allowable, you should be good. If the max stress is higher than that, you should change your design to have it in that range.
Let me know how it goes.
