brick masonry Struts
Kasim
1. i am working on a project in zone 3, should i consider the Brick masonry struts? and what is the effect of Brick masonry struts on moment and Axial force of columns, '
2. Can someone have a detail document that how to define Brick masonry Strut in Etabs
thanks
Here are my 2 cents:-
1. It depends upon whether the design code, you are following for your project, permits the use of brick masonry struts for the seismic resistance in general, and also in Zone 3 or otherwise.
   Following links discuss how some of the design codes account for the use of brick masonry infills for seismic resistance:-
   a. Brick Masonry Infills in Seismic Design of RC Framed Buildings_Part 1.pdf
   b.  Brick Masonry Infills in Seismic Design of RC Framed Buildings_Part 2.pdf
2. Discussion at the following links, might help you understand how you can model brick masonry infills in a structural software. like ETABS or SAP2000:
   a.  Modelling of brick masonry in ETABS with reference to Indian Standard Code
       (1) http://www.sefindia.org/forum/viewtopic.php?t=15975
       (2) http://www.sefindia.org/forum/viewtopic.php?t=9922&postdays=0&postorder=asc&start=0
   b.  Modelling of brick masonry in SAP2000 with reference to FEMA 273
       https://www.researchgate.net/post/How_can_I_model_masonry_infill_in_sap_2000_as_an_equivalent_strut
HTH
