Steel Areas in ETABS
Kasim
Steel Areas for Flexure Reinforcement Given in ETABS Are Always Less Than Manual Calculation because of A lot of Approximation, So Should we enhance ETABS Steel by some percentage? or put it like tha.
i mean, ACI Moment Coefficient Are Approximate and Gives moment A little higher than Etabs, which results in  higher Steel Areas, and if someone is working manually feels a little uneasy with steel Areas given by Etabs.
I have never found diff between simple moment coefficient method frame examples in etabs. Once everything is okay I can assure you ETABS results wouldnt be much different than manual ones.
