Acceptable Beam/column Capacity Ratio
Amer Barzanji
What do you mean by modifying SMRF in ETABS. What do you want to modify  about special moment resisting frame.
The moment capacity of columns at the joint for most unfavorable loading conditions should be equal to or more than 20% the moment capacity of beams framing into the joint.
