Overlapping volumes at slab beam junction
AOA everyone,
Apart from assigning the usual stiffness modifiers of 0.35 for beam, 0.25  for slabs etc , should we assign mass and weight modifiers to beams? Or does ETABS automatically account for overlapping volumes of slab at beam center line?
Also should I be taking torsion modifier for ALL the beams as 0.1? and for complex frame structures where there are irregular or non-orthogonal beams, should I take torsion stiffness as 0.1 at all? I mean how do I know if its a case of compatibility torsion or equilibrium torsion. I am attaching a snapshot of the frame. See the chamfer edge at grid 8. new modifier.JPG
Edited by Sami Ullah Khan Bangash
Hi Sami,
Overlap shouldn't be a big issue. I would suggest that you do a manual calc and compare weights. I am very confident that your numbers would match with ETABS.
For the questions:
Please see this:
The last comment on the thread address when to consider and when to ignore torsion. For interior beams, torsion can be ignored safely. For edge beams, ignoring torsion would result in higher deflection of slab. Please do ask any follow up questions should you have any.
