Rebar Concrete
done_87
Hi, I am currently renovating my house. I am trying to understand the rebar concrete drawing. Attach here is the snapshot of the drawing.What does 68XR8-125 stand for? I believe R8 is 8mm stirrups with 125mm distance apart. Also what are the significant of the distance 850 and 900. What it actually indicating. I am a chemical engineer would like to improve my knowledge in structural engineering. Thanks.
Thanks Rana for your reply. I understood on the stirrups however on the rebar from what I saw at the site there are four bar arranged in rectangular shape (125 X450). That why I still cant see the connection why that distance has any significance. Do you mind elaborating further.
The distance has significance as it shows the length in which more reinforcement is required than the rest of the beam.
Concrete is poor in compression. Reinforcement or rebars are used to provide required tensile capacity that concrete can't provide by itself. The reinforcement requirement varies along the length of the beam. For a simply supported beam (beam with 2 supports) more reinforcement is required at the middle than at the ends (like your case). Therefore, instead of providing continuous bars throughout, engineers provide additional bars where extra reinforcement is required. In that was they save on steel quantity The only catch is that the additional reinforcement should be long enough so that it develops completely. You can read more about development length of rebars here.
  • 2 months later...
