Design of Plinth Beams in ETABS
Kasim
1. We provide beams at plinth level all around the building under the walls. These beams rest directly on ground above lean concrete. Should we also model them in ETabs model???? is this practise correct?
 should we Design it Like normal beams, (More conservative) ?. Or for Reduced moment? (As they are supported along the length)
2. During seismic analysis we specify our Range from Base or Basment of The building to the top or from Ground to the top.?
3. should we include Plinth beams in our latteral force resisting system?
thanks.
Yes you should and the reinforcement in them is generally high so provide what you get from ETABS.
There are a number of threads in this forum on this topic. You can see this one:
If you are providing it, you should. Plinth would give stability to your system.
Edited by Ayesha
  On 6/19/2016 at 12:16 PM, Abdul Malik Memon said:
 one thing i would like to ask, as said by Rana Waseem provide same at top at bottom no matter what the results. One conventional practice is to increase the bottom reinforcement by 20% but why?
Moment redistribution. We used to increase bottom by 20% to account for moment redistribution in case the beam becomes simply supported due to plastic hinges. But with this 20% increase, we used to keep pattern live load factor of zero.
Live load factor zero means, in combination we make live load factor zero.? what if we do not make live load factor zero still do we need to increase reinforcement by 20%?
Can we said that a simply supported beam require more bottom reinforcement as compare to fixed?
He is referring to pattern live load not live load.
By increasing 20% +ve steel, you can justify keeping pattern live load factor as zero.
