Slab Moments In ETABS (M11 & M22)
Hira Malik
  • M11: Direct moment per unit length acting at the mid-surface of the element on the positive and negative 1 faces about the 2-axis.
  • M22: Direct moment per unit length acting at the mid-surface of the element on the positive and negative 2 faces about the 1-axis.
The Best way you can quickly pick it look towards the Negative moment   on support always provide Reinforcement perpendicular to the support for which negative moment is shown ,,
Edited by Kasim
The first thing that you need to do is turn your local axis on. Once you have done it, here is the relationship b/w local axis and 1,2 and 3 face.
  • local 1 axis: red
  • local 2 axis: green
  • local 3 axis: blue
You can easily determine your reinforcement once local axis are on.
M11 is about 2 axis so reinforcement should be parallel to Local 1.
M22 is about Local 1 axis, so reinforcement should be parallel to Local 2.
Oh alright. thanks all... so the easy thing would be to go perpendicular to the direction of contours. And if still confused, turn on the local axes. i knew it somewhere but what confused me was a model with one-way ( 32ft*12ft ) slab showing higher or same moment values for longer direction, however main r/f in a one-way slab is placed along shorter direction. So I guess its better to design slabs manually.
There is nothing wrong in designing slabs from the program if modelled properly. Yes in 32x12 slab main reinf should bd along 12 feet direction. But 1 way or 2 way doesnt only depend on just geometric properties. It also depends on boundary conditions. Basically the way a slab bends (1 way or 2 way). For m11 contours you will put reinforcement along 1-1 local direction (red) and m22 along 2-2 local direction (white). And you can rotate local axis if orientation of reinf is different (e.g. at 45 deg) or you can manually resolve components. Hth.
One way slab only acts one way if you have stiff beams (a rule of thumb would be depth at least 3 times depth of slab) all around it.
If you don't have beams and a slab is  32ft*12ft directly supported on four columns, your main bending would be along the length of slab.
The reason why one way slabs have main reinfo in short direction is deformation compatibility. Ayesha and Rana have summed your question about reinforcement nicely. The perpendicular thing is incorrect. You need to see local axis.
  • 4 years later...
