ERROR WARNING IN ETABS
Hira Malik
Does anyone know that what the simple meaning of the following warning in ETABS is?
“The maximum absolute changes in the EI and EA reduction factors is 0.2. For 102 members, the reduction factor decreased by more than the negative tolerance of 0.01. Do you want to reiterate analysis and design?”
What are these EI and EA terms?
EI is the Flexural Rigidity of a structural member (https://en.wikipedia.org/wiki/Flexural_rigidity), whereas EA may be termed as the axial rigidity (https://en.wikipedia.org/wiki/Stiffness). Both the terms are related to the stiffness of a structure, as explained in above referred links.
Edited by engruzair
1 hour ago, sameersaleem said:
change the code to AISC360-05 to lower version.
Yes i know that this problem will be solved if i use any other code. But i have to use the same and want to know the reason or explanation about this warning if any one knows it.
This is related to Direct Analysis Method of AISC 360-05, given in Appendix 7 of Part 16.1 of AISC Steel Construction Manual 13th edition 2005.
Application of this method, using ETABS, SAP2000 etc, has been explained in the following link:
https://wiki.csiamerica.com/download/attachments/9538116/AISC360-05+Direct+Analysis+Method.pdf
One-way of of checking practical implication of this message is to run the analysis & design twice. Once 'WITHOUT reiteration' and second time 'With reiteration' of analysis and design. Comparing the results of the two runs for the frame members affected by this error, you may very well be clear about how much crucial this error is.
Please share the conclusions here too, for updating the knowledge of other forum members.
Edited by engruzair
EI and EA factors deal with the residual stresses which remain in the structure, which will result in a change in effective stiffness.
The technical note for AISC360-05 Direct Analyis Method states that:
" Reduction factors to section EI and EA are automatically applied by the program .... However, as soon as a design is run the reduction factors are used and remain in the model. This means that the first time the model is analyzed and designed, users must iterate between design and analysis at least one additional time. Thereafter, both analysis and design will have reduction factors applied automatically. "
You can try changing your "Analysis Method" from Preferences>Steel Frame Design Preferences to "Effective Length" and see how that works out.
