Expansion Joint
Shahzad Ali
I am calculating building separation as per UBC 97. Should we calculate the INELASTIC Displacement either from SEISMIC FORCE or ULTIMATE LOAD COMBOS? What I understand from UBC 97 code is 'it should be calculated by ULTIMATE LOAD COMBOS'...Please provide reference from UBC97 if it is not so...
Yes you should calculate it from ultimate load combination including E. If the building has no sway under gravity loads, load case E and load combos including E will give same lateral sway.
