Building checks in UBC 97
Hussain Abid
AoA everyone.after designing a complete model,wat are the building checks to be applied in UBC97 other than Maximum inelastic displacement I.e Delta m n torsional irregularities check. can we apply diaphragms displacement check,sway check also in UBC?
THNX n regards
Here is what I found in my archives.
UBC Checklist.pdf; Preview is given below:
CHECKLISTS FOR THE QUALITY ASSURANCE OF CALCULATIONS, DESIGN AND DRAWING PRODUCTION
Please feel free to add to it, modify it, and even delete items as you see fit. Its use is optimized when personalized with your individual experiences and tailored to your projects.
This checklist is not intended to be used in an absolute or exact science manner, but rather as an efficient production tool which will likely produce better and safer designs and drawings, than if the checklist had not been used.
The checklist is not intended to be a "how-to" design manual or even a procedural manual, but rather a list of reminders to help verify that all critical calculation and design considerations have been made and that adequate and essential detail information has been provided.
Quality Assurance
It is very easy for a designer to get absorbed in state of the art calculations and design methodologies and then neglect attention to some of the relatively mundane details. These details, although sometimes tedious, are nonetheless essential for a complete and safe structure.
The use off a checklist can help the engineer remember to include or check all of the numerous items which are essential for a complete structural design.
DPIC, liability insurer of engineers, recommends developing and using checklists as a means towards a more aggressive approach to error detection. DPIC states that "Obviously, technical mistakes cause embarrassment and cost time and money. But, more importantly, they can cost lives. The true professional regards checking aids and other sources of information enthusiastically - not resentfully - recognizing that anything that produces a better final product has value."
ICBO has produced a document known as the 1994 UBC Structural Checklist. This is a 96-page document intended for engineers and plan reviewers. It basically itemizes and discusses or rewords every structural element in the code. The document is worth reviewing, especially as a learning tool. It is however a bit lengthy to use consistently on each project and, of course, it only covers Code items.
The checklist herein covers calculations, analysis, Code, design and drawing production issues. The checklist is composed of a series of keywords and phrases intended to "jog your memory" about items to be included in the design and drawing production. It is intended to be used by experienced professionals, consistently and expeditiously on each project. A review of the checklist should take less than one hour.
The experienced engineer may be likened to a licensed airplane pilot who knows and understands all the procedures to fly a plane. The pilot, nonetheless, uses a checklist prior to throttling up the runway for take-off.
Use of Checklist
The checklist consists of two main parts:
+    Calculations, Analysis and Code
+    Design and Drawing Production
The first section uses the Uniform Building Code (UBC) as a point of departure. Typical drawing sequence and materials format the second section.
It is intended that designers, checkers or principals for quality review near the end of a project will use this checklist. Internal office review practices may vary from firm to firm. Some firms perform a quality review at approximately the 30% complete stage, in order to "ratify" the choice of structural system, materials, and force criteria. Parts of the checklist may be used at that stage, prior to proceeding with final analysis and member design.
We routinely keeps a "Follow-up" list during a project. Notations are made for items that will be followed up on later. This allows the engineer to continue his current task, but without forgetting to return to a recent thought. Examples of notations made to a follow-up list include the following:
+    Add laminated wood beams to specifications
+    Get dimension of block wall from architect and show on sheet S2
+    Detail embed plate for bridging connection
+    Show CMU wall joint spacing on plan sheet S1
+    Reference soils report in general notes
+    Show contraction joints in slab on grade
+    Etc.
The follow-up list is generally reviewed in conjunction with this checklist.
While this checklist does not cover everything possible it is believed that calculations and drawings will nonetheless be improved by using the checklist versus not having used the checklist.
References
ICBO, 1994, Uniform Building Code, Structural Engineering Provisions, International Conference of Building Officials, Whittier California
ICBO, 1997, Uniform Building Code, Structural Engineering Provisions, International Conference of Building Officials, Whittier California
ICBO, 1994, 1994 UBC Structural CheckList, International Conference of Building Officials, Whittier California
DPIC, 1988, Lessons In Professional Liability, Design Professionals Insurance Company, Monterey, California
CALCULATIONS, ANALYSIS, AND CODE
Verify the that the following items have been addressed and are included in the calculations and Code checks:
Gravity Loading
1.    Review and compare initial dead load assumptions with the weights of the members chosen for final design
2.    Are Dead Loads overly conservative, i.e. very heavy such that wind uplift and lateral overturning are not safe, use .85 dead load or less to resist overturning
3.    Dead load slope correction factors
4.    100 psf at all exits, corridors, common areas
5.    HVAC Loading, RTU's, suspended equipment, tanks
6.    20 psf partition loading (UBC 94 pg 2-3)
7.    [UBC 97 pg 2-2]
8.    Live load reduction (UBC 94 pg 2-4)
9.    [UBC 97 pg 2-3]
10.    Unbalanced loading combinations
11.    Deflection, ponding, vibration perceptibility
12.    Hydrostatic uplift
See the attachment for complete checklist.
There is another checklist related to ETABS modelling shared by @Rana. I am also attaching it as you will find it useful.
Checklist_ETABS.pdf
