DUAL SYSTEM
ILYAS
CAN SOMEONE TELL  ME ''' IN ETABS  HOW WE VERIFY THAT OUR MOMENT RESISTING FRAME ARE DESIGNED IDEPENDENTLY TO RESISIT ATLEAST 25 PERCENT OF THE DESIGN BASE SHEAR .(UBC1629.6.5).WHAT IS EASY WAY TO MODEL THE BUILDING IN ETABS FOR THIS CHECK ONLY?
Edited by ILYAS
dear sir umarmakhzumi! sorry for very late reply,actually i was on leave(muharram break) that,s why i could not replied on time.
i was getting same in-plane shear in walls after reducing the stiffness modifier of walls(0.001).but now anyway problem is solved,thanks.
If you share your found solution with this forum it would be of great help for others. Thanks in advance.
  On 12/21/2016 at 1:56 PM, Rana said:
No way Ilyas. That will reduce the total base shear. Wrong approach.
As umer makhzumi bhai said, for seperate model without shear walls, the approach told by ilyas should be ok. But I doubt the interaction with shear walls is not taken into account if we design frame for 25% shear separately. Kindly share you solution how to cater it in etabs.
The interaction of frame and shear wall would be considered in the first model with full V. Second model is to check frame only.
  • 6 months later...
  On 7/6/2017 at 1:36 PM, YasirNaeem said:
Sir what will be the modifiers for walls and column then?
What Rana means is to play with the wall stiffness modifiers till you get 25% base shear resisted by columns. This is different from standard stiffness modifiers applied to each structure irrespective of their geometry as per Section 10 of ACI.
Generally we reduce the f22 f12 m11 m22 m12 modifier to 0.35 assuming that the wall is cracked so base shear will diverted towards column. This results in reduction in area of steel of shear wall. Moreover we put 1 in f11 because we believe that shear wall is taking 100% in plane force but the judgement between f11 and f22 is based on your structure.
Moreover you check and compare stress with modulus of rupture to judge what value is to be used i.e 0.35(if stress exceed modulus of rupture) or (between 0.35 and 0.7)
Thank u
