Multilevel Raft Foundation
israr_sari
How to  import multilevel raft foundation from etabs to safe.
main designer has designed it as a raft foundation with a bearing capacity of 150 kn/m2 but after the site development and excavation we found a hard strata that can with stand with 250 kn/m2(as per the soil report). as total depth of raft is 1 m that is too much for 5 storey car parking, i want to modify it with 250 raft overall with inverted panels under column. but i am not able to import that multi level foundation reactions as a one file in Safe. because in etabs u can only export one storey .
please give your helpful suggestions.
  • 5 months later...
Practice is different in different parts of the world. Here in Norway, geotechnical engineers are responsible for everything which will be built in the ground. But, structural engineers also do their part for foundation design wherever needed.  for example, pile foundation; geotechnical engineers do their calculations in geotechnical FEM system and give spring stiffness data to structural engineers and they calculate piles as integral part of their global structural model with soil springs. Values for deformations, moments and load distribution from global structural model should match with geotechnical model. If they dont match than it becomes a iteration job between structural and geotechnical calculation until they get more or less same results.
1) More interaction between the geotechnical and structural engineer after the structural engineer has reviewed the geotechnical report and started design work. During this conversation, the structural engineer should:
Talk through their understanding of the geotechnical recommendations.
Explain what has been done or will be done concerning site grading, basements, building location, and footing bearing elevations.
Provide the magnitude of the loads on the footings.
Break out the live loads between persistent and transient loads so
that transient live loads do not drive the design.
Explain the range of footing sizes that will be used with the allowable bearing pressure provided in the geotechnical report.
For combined footings or a mat that uses a subgrade modulus, give the geotechnical engineer the elevation and size of the mat/footing, and ask if the subgrade modulus is applicable or needs to be modified.
Request that the geotechnical engineer checks their recommended bearing pressures to see if the bearing pressure can be increased now that they have actual loads and know what soils the footings will bear on.The fact that the geotechnical engineer develops their understanding of the soils by sampling only about 0.000015% of the soil under the site,,THANKS
