Amplification of accidental torsion (drift vs displacement)
WR1
In order to amplify accidental torsion, as per UBC-97 and ASCE 7-05, maximum and average displacements at corners of floor plates must be compared.
However, in csi wikki, they use the word "DRIFT" not "DISPLACEMENT", so drifts should be compared instead of displacement.
Drift: Difference of displacements at a specific point of upper floor and lower floor
Displacement: Abs elastic or in-elastic displacement with reference to base
I went through ASCE 7-10 but it was more confusing, as in the text they use word "DRIFT" but in the formulas they talk about "DISPLACEMENT".
In FEMA examples, they are sometimes using "Inter-story drift" and sometimes "displacements".
Anything I am missing here?
I think both will indicate the torsional irregularity at a level in the building.
The ETABS gives those results in the summary report; the software reports in term of maximum and average displacements and their ratio at each story.
Yes, both give an indication, but i was studying where both methods make a difference. Usually in books, for example in
Elements of Earthquake Engineering and Structural Dynamics
By André Filiatrault
https://books.google.ae/books?id=3FRzzDLlQwYC&pg=PA457&lpg=PA457&dq=drift+vs+displacement+to+check+torsional+irregularity&source=bl&ots=oEgfxDf-eS&sig=agIoyGCOOwtUo301UpQnrpCTRNo&hl=en&sa=X&ved=0ahUKEwiMnbDA9afRAhXBJ8AKHdzrCXI4ChDoAQhDMAg#v=onepage&q=drift vs displacement to check torsional irregularity&f=false
it is calculated based on drifts and not by displacements, so the rotation of lower floor is also important.
