Trosional Rebars For Edge Beam
Khalid Iqbal
right way is to put torsional bars and distribute based on width to height ratio along sides of the beams and also at top and bottom of the beam. but some times if it is very less...we put just add it to top and bottom of the beam as the section may not be so deep! but ofcourse you cannot ignore equilibrium torsion...there is another torsion called compatibility torsion! just search in ACI you will find the terms!
True, Its important to know if its equilbrium torsion or compatibility torsion. If you know that you can decide the level of risk you can take by not doing calculations.
