ECCENTRIC LOAD IN ETABS
Hira Malik
And in LIFE as well
  On 1/21/2017 at 9:20 AM, ILYAS said:
Bcz everyone in structure is right if he/she is using rational approach,no matter what different technique we are using,thanks
Waqar, I did not get how you modelled.
  On 1/21/2017 at 12:19 PM, waqar saleem said:
i confirmed this by making a model in SAP and load transferred, there was not any error. @Rana Rana sab please shed some light.
Hira, null lines will not transfer anyload, you have to apply a very small section to null line for proper load transfer.
  On 1/20/2017 at 11:30 AM, Hira Malik said:
I think Mr. Ilyas is right. I drew a none property section from center to center of two columns and applied load on it. ETABS says "the load is not transferred".
What I meant to say and what I understood was, there is only one single line column in the model, so you have two options.
1. Select top joint of column line and apply joint loads (P and Mx,My) or draw a horizontal line with length equal to e at top joint of column and apply the P at the other end of this line.
  On 1/17/2017 at 12:41 PM, Rana said:
Apply the moment manually or draw dummy cantilever line.
Why dont you simply assign insertion point to model this eccentricity? If you are having a frame, You can assign these insertion points to either the beam or the column a per situation? You can offset any end of member (Column or Beam) by this method to model eccentricity. If you are having a frame, and want to model the eccentricity at a specific joint, select the member at that joint (the member which is offest from center lines) and go to assign manu--> Assign insertion Point--> and assign desired offset nd desired axis. But dont forget to uncheck DON'T TRANSFORM STIFFNESS otherwise only geometry will be offset instead of stiffness i.e. required in calculations by the software.
If you having only one column, You can also o the same, You want to provide eccentricity. You can either offset your load point as said by sir Rana, or you can offset your column centroidal axis by applying required offset in insertion points in desired axis. again dont forget to uncheck DON'T TRANSFORM STIFFNESS.
  • 5 years later...
