Modelling Two buildings near by
Rahulkld
Hello everyone, I tried modelling two buildings which are close to each other in ETABS. When i tried to see time period at different modes. Etabs animated one building only for a particular mode. How does Etabs deal with such models? How can I see the animation of both building at once???
  On 2/10/2017 at 6:41 PM, UmarMakhzumi said:
It is a very good question. I was in a similar situation recently but I separated my models. Wonder how do softwares consider that..
You can use ETABS 2015 or higher and use 'Tower' option to separate both buildings in the same model.
I got it sir. The mode shapes of two structures that are not connected to each other are independent. That's the reason ETABS not show the mode shape animation of both buildings at once. If you whant to evaluate the interaction of two buildings that are close to each other (e.g. the damaging contact during a seismic event), a dynamic modal analysis is not the way, this is a non-linear problem. A way to assess this issue is connecting both structures with gap elements and performing a nonlinear time history analysis.
Thanks. I forgot to state that I was using RISA3D but its good to know options available in ETABS.
You can also use the formula for maximum inelastic response displacement to separate the buildings. Check this
