Lateral Torsional Buckling prevention
groszni awesome
Assalamualaikum SE Pakistan,
Im designing a steel gable frame with a large span about 28m, and the LTB for beam design govern the design. i have the lb (braced length of flexural member) is the same as actual length (no bracings) so i gotta enlarge the section.
1. how do you properly braced the beam? please include some pictures
2. does adding a web stiffener is the same as adding a bracing?
3. could the purlin acts as the same as the bracing does?
best regards
I don't have pictures but there are 2-3 topics on this forum on LTB. You can search them. Connection of bracing is generally done at top flange and then stiffener is used to engage the full section.
No.
No.
I would suggest using a steel textbook and see example of built up section. That would help you understand the use of stiffeners. Also, you could look up LTB in the book. Beware of use of intermediate beams to reduce unbraced lengths as they don't reduce unbraced length for LTB. Its tricky.
Edited by UmarMakhzumi
Updated my response
