Expansion joint in irregular building
Waqas Haider
Assalam o alaikum,
I m attaching plan outline of a building quite irregular in plan. As generally, expansion joint is provided at 150ft spacing, in my case, After 150 ft, The building changes its geometry and direction of plan so Cant Decide whether it needs an expansion joint or not. It also have a big void which is an open yard in the middle of building. If expansion joint is needed, i have also marked a proposal line. Does it seem ok?
Building plan outline.pdf
Information about expansion joint is mostly empirical. I have seen some handbook that allow joints till 250-300 feet. You can always apply temp loads in software and see if provided configuration and design works or not against temp loads.
I have never applied temperature load in buildings. Kindly guide where can i find code guidelines about when it becomes necessary to apply temp load and how to apply it?
Avoid it. Totally avoid it. Just put the expansion joints.
