dear all,
i have some questions and i am hoping to find some answers from you kind people.
1) when we use doubly reinforced beams how can be obtain economy be controlling ceiling height ?
2) where do we use bar curtailment and bent up bars in beams because there are not ACI provisions related to bar curtailment (as far as i know)
3)i have seen examples in books they calculate steel area for beams and they provide combination of different dia bars to satisfy that area why they do it because they can satisfy same area using same dia bars ?
4)which design method Etabs uses. LRFD or ASD?
5) how do we design the hanger bars. what is ACI provision for it?
6)where do we use inclined stirrups in beams ?
7) how the longitudinal reinforcing can be used as shear reinforcement ?
Thank you all in advance. Looking forward to your responses.
Generally speaking, heights constraints are rare in real life. I would rather keep my beam as a deeper singly reinforced beam rather than a short doubly reinforced beam. Per theory, you can use doubly reinforced beams where there is height restriction.
Read ACI Chapter on development lengths.
Keeping same diameter bar is preferred as it is less work for construction and makes things simple. You are correct in pointing out that books don't show a practical approach towards design when mixing different bar sizes.
Depends what you choose.
Look up a text book. Macgregor has some examples.
We don't.
It can't be. There might be some application under Strut and Tie Model but not in general.
I would just like to add that please don't group your questions in one thread. I have answered your questions but generally I have seen such threads go unnoticed as there are too many offshoots to answer and its hard to tag a thread with a specific category if it has many questions.
One example is to transfer of diaphragm forces to shear wall, if the wall does not have collectors, or drag members. The flexural reinforcement of slab will transfer in-plane shear of slab.
