Difference of moments in Etabs and Safe
uzi123
Dear All,
AOA,
I have an observation that i want to share with members. I have observed that Etabs analysis gives higher moments in framing beams if you export the same modal to safe for design of Slab. I can't really make out the reason for that.. Any justification for this difference?? attached files are results from respective software. Etabs giving M= 472k-ft whereas the corresponding safe value if M= 405 k-ft
Questions to consider are:
Where does your manual calculation stand.. closer to ETABS or Safe? Does reduced moment in beam result in higher slab moments in SAFE? Are the softwares you using cracked or original?
  • 3 years later...
if we are running cracked section analysis then which moments we should take. safe or etabs?
in my scenario. i have 44 feet long span with section 12x27 beam section for retrofitting. at site cracks appear which are due to deflection in my opinion. so for retrofitting, we need to take safe moment or etabs moment??? values difference are more than 80 kips ft in safe and etabs.
