Line Loads for Frame Structures in Etabs
Memli
Dear sir/madam
I am having problems defining frame loads in ETABS.
I have modeled my Line Loads (partition load) with Nule frame and assigned frame loads in those nul frames. The problem is that when I run Modal Analyses I am having huge values because the joints on nul frames seem to be part of structures and they can be seen as moving around in Modal animation.
Any help...?
Many thanks in advance
Edited by UmarMakhzumi
Updated topic title to make it more relevant to the asked question.
10 hours ago, Memli said:
Hello,
huge values of Natyral Period of Vibration .
Whats a dummy frame?
Dummy frame is just another section defined as 50mmx50mm.
Try this and then update us if still T is higher.
