Shear profile for an infilled RC frame
Samra Masood
I have done a pushover analysis of 3-storey 1-bay masonary infilled frame using opensees  and as i look into the shear profile of the frame at various time steps the shear in cols is a little negative intially and then becomes positive and the increases in the positive direction with the increasing lateral load until the infill breaks.... why is it negative initially (i.e. in the elastic range)?
Can you please share how the load has been applied to the 1-bay, 3 story masonry infilled frame?
Also, what is "openness" ? It would be beneficial to see the deflected shape at different time steps. In general principle the response of a frame modelled with masonry struts should be similar to that of a braced bay. I can't think of a reason why the col shear is negative in elastic region other than application of load that causes negative shear and then with time the load changes and so does shear. It might be beneficial to look at how load is being applied with time and we can discuss it.
Thanx for your kind response, for those who are following the post, i have figured out the problem and thought to share so that others may benefit from it. Actually the results that appear slight negative initially are due to the gravity analysis done before, as the load later increases with each time step the lateral force on frame increases leading to positive shears in cols.
  • 5 months later...
Plz send the procedure of design INFILL FRAME in ETABS
