ACI 318 clause for beam and column definition
Samra Masood
According to ACI Concrete Terminology 2013,
a "beam" is defined as " a structural member subjected primarily to flexure but may also be subjected to axial load."
Whereas, a "column" is a "member with a ratio of height-to-least-lateral-dimension exceeding 3 used primarily to support axial compressive load."
Design of a structural member (as a beam or column) in ACI 318 code is based on above-mentioned definitions.
Yes.
ILYAS is right.
Definitions of beam & column are also given in Section 2.3 of ACI 318-14.
In earlier versions of the ACI 318 (2005, 2008, 2011 etc ) definition of column was also given in Chapter 2. However, definition of beam was not included till then. Rather it was referred as a flexural member.
AFAIK definition of "beam" was most probably included for the first time in 2014 version of ACI 318, after  it was included in ACI Concrete Terminology 2013.
Edited by EngrUzair
Beams are flexural members only  designed for the major moment and shear without axial load effects.
However, column design is more accurate as you can account for biaxial bending plus axial load effect on shear. Infact all the beams can be designed by this approach. However, generally beams do not have huge axial loads or minor bending. Thats why it is simplified.
