PICKED UP RC COLUMNS
zenith.international
  • 4 weeks later...
  On 9/12/2017 at 7:17 AM, ILYAS said:
1-picked up columns will not be part of seismic load resisting system,so thay are treated as secondary frames and design procedure will be same as for usual columns
Not true. It depends on how you are designing. Also depends on the stiffness of column as well as the supporting slab.
If the supporting slab has not much stiffness, the pickup columns act like hanging threads carrying no load at all.
  On 9/13/2017 at 4:49 AM, ILYAS said:
NO designer will consider picked up column as part of lateral force resisting system
It could be. All depends upon relative stiffness. Their are buildings where column configuration changes after X number of stories. The floor at that specific level is very very thick to allow for new columns arrangements (and satisfy other limit states requirements) but this happens all the time in high rises in Dubai.
Picked up columns are different from normal RC columns in that at their lowest point, these are located on (picked up from) top of a beam at some upper story of the building & transfer the load to the supporting beam, instead of trasferring it  to a lower column directly.
In the following image (showing elevation view of an ETABS model, where vertical purple lines represent columns, and horizontal lines represent beams), second column from left, is a picked up column. It is starting from top of a beam at first floor level, unlike all other columns stsrting from the 'base' i.e., ground level.
Edited by EngrUzair
