Rigid and Semi rigid diaphragm
Aye Min Khaing
What is difference between Rigid and Semi rigid diaphragm. I think if we assign semi rigid, We don't need to consider accidental torsion i.e 5% eccentricity. If we assign rigid, we must consider accidental torsion. And next question is difference between XCM and XCCM in case of rigid diaphragm. What is MassX and MassY. How to calculate XCCM and YCCM. And how they work.
A rigid diaphragm would not deflect on its own when transferring loads to vertical load resisting system. That is why it is called rigid - all points move the same. A flexible diaphragm however would deflect when doing the same. So  for rigid diaphragms, loads are transferred to vertical load resistance system members based on their stiffness, where as for flexible diaphragm, the tributary area of diaphragm to a member is critical in determining how much load gets transferred to it in addition to its stiffness. This is the general principle. There are also two topics on this forum that you can look at.
I think the 5% eccentricity check applies to all kinds of diaphragm. I am out of practice for some time so other members can comment on this one if I am incorrect.
Check these threads.
