Boundary Element length determining query.
Muqtadir
c >= lw/(600(du / hw ))
This formula determine's whether we will be requiring the boundary element or not. But how to find 'c'?
Everywhere it says that we have to perform strain compatibility equation. I can understand concrete will have a 0.003 at one end but what about the other end? and also we have quite many steel bars in between both ends, not as simple as a beam. Kindly help in this regards.
Strain compatibility means C=T equation for reinforced concrete design.
The other end is in tension. Bending of wall will create compression at one face and tension on another.
You can assign Tension forces at different bar levels as T1, T2, T3 and so on and use C=T to find the value of small 'c'.
Hope that helps.
But isn't this impractical?
for every iteration of steel in the wall, a new 'c' will have to be found.
4 hours ago, BAZ said:
Reinforced concrete design, 6th Ed., by Mac Gregor and James K Wright
From the book, I came across this method (quoting the book). I wonder since I'm not experienced, How do experienced engineers decide on when to introduce boundary elements in the wall and when not to? Finding of c then using the formula as quoted before to come to a conclusion or engineers have a thumb rule which I'm not aware of?
This question is for you too umar bhai, what is your approach, if you wouldn't mind sharing?
Edited by Muqtadir
