Corbel action on Column analysis
Don Ruc
I have a doubt that how the RC corbel action(Tie action) is applied to the RC column analysis
Is it correct to applied it as a Pxav(P- vertical action on corbel, av- distance between root of corbel & line of action) or as a Tie force which counteracting the column compressive load. Consider that the RC corbel and RC column are non precast element
Make a free body diagram. Corbel transfers loads to column like any rigid attachment to column would. It would transfer a moment and axial load to column. The tough job is to design corbel itself. You should use Strut-and-Tie method for corbel design.
Edited by Ayesha
  • 4 months later...
