Shell Stress Interpretation
aka
Attached is a thin plate stress distribution done in SAP2000.The units are KN-m.E value is 210GPA ,and the area section so choosen is shell thin with plate thickness t=20 mm, the thin plate is idealized into two triangular element with a 'None' element to connect two area elements at the diagonals. Along x axis is 400 mm and y axis is 200 mm.The manual calculation matches exactly for the displacement at nodes.However,the shell stress is not matching .As per manual calculation ,the sigma x and sigma z are coming out to be 6964.53 KPa and -7.53 KPa respectively. However in Sap2000, sigma x or S11 is about  6859.44 Kpa,while S22 is about 990.34 KPa and S12 or Txz is about -97 KPa from the calculation whereas from manual calculation it is -16.1 KPa???why is it that ,is it because it is not meshed or so? Please spread some lights on shell stress and my understanding on it .I have attached here the stress contours and displacements.
stress.docxFetching info...
