Flange brace design
groszni awesome
Consult the document titled BRACING FOR STABILITY.  Bracing is a function of the compressive strength of compression flange. As a rule of thumb, bracing force can be considered as 2-3% of the coompressive strength of the compression flange of beam. Read the document for better estimate.
I would like to add the following comments to what has been said earlier:
1. The document referred by @BAZ, is available at following link:-
AISC-Bracing for stability
2. Additionally, the following research report (especially its chapter 6 & Appendix B ) provides useful information on undrstanding & design of bracing:-
Bracing Requirements for Elastic Steel Beams
HTH
On 10/5/2017 at 6:06 PM, groszni awesome said:
How do we design flange brace to resist LTB on structural steel beam? Whats the mandatory force to design it?
You should design it like you would deisgn a normal brace. The only thing to look for is that to make sure that you have considered the eccentricity b/w the flange and the brace. Consider that eccentricity in the design of brace. Other than that, it is pretty straight forward- design of member with axial force and moment at ends due to eccentricity of axial force (beam-column).
thank you, would you mind if i ask you to draw the mechanism?
thanks.
For the design of flange brace you need to check the restraints strength of the member as per your code limits. Based on the restraint length you can get the force required to design your brace. Sir Umer and sir Zeeshan correct me if I am wrong.
Thanks,
thanks.
For example, if you have used a single angle for a brace, then because of the eccentricity of the angle to the connecting beam,  you will have a moment Mux in addition to axial load and you will need to do beam column capacity check for this member. There wouldn't be any Muy.
