Stiffness Modifiers
AMRITHA
The stiffness modifier for beams = 0.35I column = 0.7I and slabs 0.25I. they are required to consider the cracking of the members. my question is why do we consider 35% of stiffness for beams while code says we can use 70% of stiffness for columns? what is the significance of the numbers 35 , 70 , 25??
The beam is a flexural member, and the column is an axial+flexural member. So, the beam will experience more cracking than columns. These numbers are deduced from experimental results ( read the commentary of ACI section 10.10.4.1).
  • 2 years later...
Dear Badar, I read your comment somewhere on section modifiers to use uncracked modifiers for obtaining stresses/forces. I'm now looking keen into this issue as I was modelling a structure and the columns had more than 6 sq.in difference of reinforcement between uncracked and cracked (with cracked being the greatest). I was just thinking about the UBC-97 code defining the section modifiers for the lateral force resisting systems. Code has specified three lateral force resisting systems as moment resisting frames, Braced building system and dual systems. Now if you play with the modifiers in each of the case you will see how the load distribution behaviour in the building system is. It means that section modifiers do play a crucial role in design and should be used as given by ACI for beams,slabs and columns accordingly. Also strength based design comes into play after concrete fails in tension and we know that even if steel is provided, cracking of concrete will occur prior to the yielding of steel.
I'm sure many professionals are still facing confusion on this topic and it needs to be addressed. Would like to have your useful insight on it. Thank you!
Edited by abbaskhan2294
Both practices, with and without stiffness modifiers, are followed to decide about the reinforcement requirement against the design forces. Both approaches will lead to a stable structure as long as mechanics holds.
Having said that, the stiffness-modifier approach is more conservative, and is better representation of the actual conditions in most cases; one would expect columns to be less cracked than beams, and consequently will attract larger share of unbalanced moments at beam-column joint as compared to un-cracked scenario.
