Doubly Reinforced Beam
Dear All,
Is it possible to tell about a beam section from looking at its top and bottom reinforcement that either it is singly reinforced or doubly reinforced? no other information is provided, only top and bottom bars are provided say 3#4 Top, 3#6 Bottom, B 12"x18" .
Yes, provided you know (or able to estimate) the concrete compressive strength & reinforcing steel yield strength.
Calculate required maximum steel area per code (corresponding to Maximum Steel Ratio in tension), for the given beam size & compare it with the actual (provided) steel area.
In case actual steel area in tension zone is more than the Code Permitted Maximum steel area, and the reinforcement area provided in compression zone is at least equal to the excess amount of reinforcement area provided in tension zone (= the difference of actually provided minus Code Maximum steel area in tension), the given beam will be a doubly reinforced beam.
Well explained by Uzair.
Generally, whenever you see more reinforcement on top, it indicates either the beam is doubly reinforced or it is continous. In your case, it appears the beam is singly reinforced as nominal steel is present on top.
