Design of Industrial RC Structure having Heavy machinery in Upper story
EngrJunaid
AoA, Hope you all will be fine and in good health.
What factors, codes and limitations should be kept in mind while designing a two story (Ground+1) industrial RC structure.
There are 3 machines (12-ton weight each) on first floor and about 120 psf is the area load.
Edited by EngrJunaid
Use MBMA (http://www.mbma.com) guidelines and codes. You need to consider inertia forces from crane to supporting structure that would be applied when the crane stops. All that information is in MBMA guideline. You can also check out the Canadian CISC Crane Supported Structures Guideline. It is freely available, so I have attached it.
CISC_crane_support_steel.pdf
Thank you @Ayesha for your kind response.
This will be Reinforced concrete building. I am worry about the effect of machine vibrations on floor Slab and fatigue stresses caused by the machinery.
My question is how to consider the machine vibrations in design of RC Structures.
Oh sorry. I thought by Industrail you meant Crane Supported Structures and the weights provided were that if crane / gantry. But if that is not the case and you have a vibratory equipment the you can ignore my comment. What kind of machinery would you have? Would they all be  at ground level?
Yes i got your first reply was about steel structure and the document you share is very detailed and helpful.
There will be 3 Machines each of weight 12 ton on first floor level.
Till now i didn't get full detail about the machine vibrating frequency and other operational data from the client.
So, there is a topic on the forum with all the information. You can review it and post any questions still unanswered after that. I skimmed through it and looks like first you need to know what kind of vibratory equipment/ machine you have and then act accordingly.
 machine foundation (ACI351.2-10,ACI351.3-04).
and for floor vibration ISO 2372
