Column Design In Etabs
Dr Yueh
  On 11/18/2017 at 2:45 PM, Saiful Islam Zaber said:
while all the beam are connected concentrically to column how can there be such large minimum moment ?? See the Column in grid E4
8.bmpFetching info...
You are not getting the point. Have you referred to the codes? Aci or bs or whatever? An interior column with huge axial load multiplied by minimum e can produce huge moment even if the original moment from frame is 0.
Eccentricity can be due to construction activities. There is always construction tolerance that needs to be considered in design.
