Difference in result betwen FEM and strip in SAFE
Leomessi90
Hello every one
i modeled a flat plate with SAFE and after i run the analysis i got different results when i compare FEM with strip Forces for both M11 and M22
these is so much different .
one more thing  , i solved the same example with direct design method and when i compare it with Strip forces from SAFE there are good agreement , but when i compare it with FEM result by SAFE there are big differences !!
does any one have information
thanks
  • 6 years later...
  On 11/15/2017 at 6:31 AM, Ayesha said:
The moment in the contour are kNm/m. You need to convert that to strip width. Please see another topic on the forum that explains how to read and interpret plate moments.
Hi there, I had the same issue, and the FEM results in tables are per unit width (1 m), so Modeled the strips with 1 m width, and the results are way much different (almost 50% less than those on fem results table !! so what would be the problem?
