Importing from Etabs to Safe
Omar Khalid
Hello,
I exported a story from etabs to safe and checked the results it turned out safe always gives me lower moment result for beams and by exporting it doesn't import neither property stiffness modifiers nor end releases assigned in etabs. After I have assigned moment release manually in safe nothing happens. The negative moments is still present why is that ?
