RC Embedded Columns
Don Ruc
Hi members
During modelling, Is it required to model the embedded columns(modelled as frames) embedded with a RC retaining wall(modelled as a shell) or is it possible to ignore the column in the analysis and provide nominal reinforcement in the column. But since this column is required at upper levels, It will be floated at the termination level of the retaining wall in case of ignoring the frame. Please clarify which approach o be followed is correct??? Please Refer attachment. I am performing a FE analysis using ETABS
Thanks in advance
Edited by Don Ruc
  On 11/20/2017 at 10:44 AM, Don Ruc said:
If the RC wall is a shear wall rise up with the embedded column, is it still necessary??
Yes.
In both cases, you should include the said column in your model. It will make your structural framing more stable, due to availability of an additional vertical support for the superstructure.
