Diaphragms
Shariful Islam
Hi
I want to know the use of diaphragms in etabs. i discus many people who are use etabs but i can't get justified answer about the application of etabs.
I read the Technical reference  of  Etabs, where they write about Diaphragms. i get two type of diaphragms (plate or shell and joint or beam).
My question.
1. When do i use Shell diaphragms (if floor present )
2.When do i use joint diaphragms ( grade beam level where no slab are provide)
NB: Diaphragms use to transfer the lateral load to the resisting element ( frame such as column. beam,shear wall)
You will assignment diaphragm property to your joints when you are not modeling area elements ( shells, plates or membrane) in the model, but the joints are connected by a horizontal area-member, or some combination of line-members, that will act as a diaphragm in the actual structure. ETABS will use it to distribute lateral forces to all joints based on that diaphragm property.
