Steel Design by ASD or LRFD?
Muqtadir
Working on a steel structure, I used LRFD as well as ASD. The fact that some components of the structure fail in ASD while in LRFD they pass with nearly minimum stress ratios, has left me in an awe.
Kindly put in your reviews to which methodology should be adopted and what might be the flaws in using ASD or LRFD concerning Steel Structures. Thanks.
ASD is an older method that is still practised by a lot of mechanical engineers to size pressure vessels and tanks. However, for structural engineering, everywhere, LRFD is used.  Here is a detailed answer I read once somewhere on the internet and saved it as it was very interesting.
  Quote
It really boils down to how you apply a safety factor to the design of members.
OK - my stupid analogy:
You have a small stream and need a log to drop over the stream so your ballet cow can dance across it.  The log needs to be strong enough not to break under the weight of your cow and it needs to be stiff enough so the log won't sag too much under her weight.
Cow weighs 500 lbs.  Log spans 15 feet.
ASD
You know that the wood of your log can be stressed to 1000 psi before it breaks.  So you need to find a log large enough so that the wood is not stressed to 1000 psi.  In fact, you want to limit the stress with some safety factor to make sure that you are OK.
So you find a log large enough such that the stress is limited to only 600 psi.  (i.e. your maximum allowable stress is 0.6 x 1000 = 600 psi.)
So you have a safety factor against failure of 1/0.6 = 1.67.
The equation looks like this:
fb = Stress from weight of cow
R = Strength of log
0.6 = safety factor
    0.6 x R   >   fb
LRFD
You still know that the log can be stressed to 1000 psi before it breaks.  You also know that the weight of the cow used to find the stress in the log might be plus or minus a few pounds.  So because of this uncertainty you apply a safety factor to the weight of the cow -say 1.6.  Also, you know that the 1000 psi limit varies a bit with different logs so you apply a little safety factor to it - say reduce the 1000 psi to 900 psi just to be safe. (i.e. 0.9 factor)
So you find a log big enough so that it will theoretically break when a 1600 lb cow is placed on it and you only count on 90% of its strength.
So the equation looks like this:
R = Strength of log
0.9 = resistance factor
1.6 = load factor
     0.9 x R  >  1.6 x fb
What LRFD gives you that ASD doesn't is the ability to use different load factors (the 1.6) depending on the variability of the load.  Dead loads you usually know pretty well.  Live loads vary all over the place.
Also, the resistance factor can be varied depending on the variability of the strength estimates that exist with different materials and different failure modes.  Abrupt, highly variable failures need lower resistance factors
while flexible, ductile failure modes can have higher factors.
I've used stress in my LRFD example, but most LRFD specifications use moment, shear, or force variables instead of stress.
LRFD allows proper, balanced statistical probabilities of failure while ASD has a single safety factor independent of how well you know your cow.
