*SEFP Consistent Design*
*Pile Design*
*Doc No: 10-00-CD-0007*
*Date: April 16, 2018*
  • Longitudinal bars of beams, or slab, must be able to develop their yield stress, so that the beam/slab can transfer moment to joint. It means that longitudinal bars must have adequate development length for hooked bars. This implies that the size of the column must be such that bars can develop their tensile forces. If bars can transfer moment, they can also transfer shear as far as monolithic construction is concerned.
  • The shear strength of the joint must enable the transfer of moment and shear through it.
  • The joint should be Constructible: Congestion of reinforcement is the main concern.
For the joints part of the special moment resisting frame, the shear force will be the one that corresponds to the development of hinge in the beam because the frame is required to satisfy strong column-weak beam criteria. If it is a knee joint, then joint area must resist the shear equal to the development of tensile force in the beam. The tensile force will be equal to the product of the area of tension steel, yield strength and the factor that represents the overstrength of steel rebar. If it is not a knee-beam-column joint then, the design shear of the joint will be algebraic sum of tensile force in the beam and the column shear. The column shear is the one that is required to keep the joint in equilibrium, i.e the shear corresponding to the development of the probable moment capacity of beams at the joint.
For the joints not part of the special moment resisting frames, one needs to investigate whether the beam or column will yield first. For knee joint, if the column is weaker then the beam, the tensile force cannot exceed the moment corresponding to the development of hinge in column
1.6.THE JOINT: Definition and classification
Portion of column within deepest beam that frames in to the column (ACI 352-02).
ACI 352-02 categorizes joints based on the displacement-demand imposed by connected members.
·        TYPE 1 (Section 2.1.1 ACI 352-02)
These joints possess limited ductility, and hence the connected members are designed for limited ductility. They are used in situations where ductility of structure is not a concern.
·        TYPE 2 (Section 2.1.2 ACI 352-02)
These joints connect members which designed to have sustained strength under large deformations.
Joints are also classified based on their location in framing system
1.7.THE JOINT: Design forces
The joint is designed for the shear that results from attainment of the flexural strengths of members connected at the joint for type 2 joints. For type 1 joints, same principle is employed, unless the both members are overdesigned and the engineer does not expect both members, i.e. beam and column, to yield under design forces.
1.7.1. FLEXURAL STREGNTHS: TYPE 2
No strength reduction factor is used for computation of flexural strength. Steel stress is multiplied by factor of 1.25 for computation of flexural strength (3.3.4 ACI 352-02). For type 2 joints, the flexural strength of beams needs to be calculated only, as we do not expect the hinge-formation in columns; we will proportion the beam-column assembly of this joint as per strong-column-weak-beam approach.
The slab reinforcement within the flange of beam must also be considered for computation of flexural strength of beam if the slab is integrally cast with beam and if the longitudinal reinforcement of slab is anchored (3.3.2 ACI 352-02).
For interior connections, and for exterior and corner connections with transverse beams, the portion of slab to be considered as flange should be as per guidelines of section 6.3.2 of ACI 318-14. The effective flange width should not be taken less than 2 times the width of beam.
For exterior and corner connections, without transverse beams, the effective flange width should be as per figures below (section 3.3.2 of ACI 352-02). The effective flange width for this case need not be taken more than 1/12th of the span of the beam.
1.7.2. FLEXURAL STREGNTHS: TYPE 1
For type 1 connection, similar procedure as discussed above should be used, if beams are expected to yield before columns. The stress multiplier factor for this type of connection can be taken as 1.
The beam reinforcement, if any, as per section 24.3.4 of 318-14, with-in the effective flange width, must be included in determination of flexural strength in addition to the web reinforcement.
If columns are expected to yield before beams, the nominal flexural capacity at beam-column joint should be calculated with due consideration given to the axial load on column. The beam moment in that case would be the one required to maintain equilibrium of the connection.
If neither the beam, nor column, is expected to yield at factored loads, then the design shear of joint would be based on factored forces, moments and shear, at beam-column interface.
Some issues regarding Joint Design in ETABS
i. For slopy/inclined beam, ETABS considers them as braces, so it does not report shear forces on joint and one gets stuck how to handle this situation in SMRF. Is there any work around to take care of this situation.
ii. For eccentric beam on columns (peripheral beam flushed on one side of column), joint area is not calculated taking into account the flushing effect even if we try to induce eccentricity through cardinal points or offsets. This can get un-conservative.
iii. For irregular shaped columns (not rectangular), ETABS takes the joint area equal to the sectional area of columns which can also result in un-conservative design.
How to take care of all the above situations without getting into manual calculations which gets very tedious and unproductive in design houses.
Thanks in advance and best regards
tachauhan
