Design of steel fencing against wind loading
Dear All,
I am working on modelling of steel fence on etabs. I have to provide green sheets over the entire fencing , for privacy issue. Previously it was working ok(without wind load).
So I have modeled it with wind loading and just want your input if the load combos are OK or not.
Also any other suggestions would be appreciated.
PS. I don't want to change the gauge of steel, inclined bracing would be preferable.
Fence Model Inclined Bracing.EDBFence Model Inclined Bracing.ebkFence Model Inclined Bracing.$ET
I am not sure why you doing it in a software. A simple hand made analysis would suffice. Also I am not sure what do you mean by load combinations? I mean, there should be just one wind load combination 1.6W for ultimate moment. Dead would not produce moments in the wall/supporting structure.
Then you add 0.6D of overall assembly with 1.0W for checking service tension and footing design.
