Foundation load combinations for Design.
adilkhan
Foundation load combinations . i am analyzing concrete frame structure, i have assigned load combination of service (dead, super imposed dead ,live load with Earthquake + and - direction). after analysis run  i found that due to one of the combination with Earthquake load there is support reaction in downward direction which shows that there is tensile force produced at that column or location. also the compression or upward support reaction value is much greater ( cross limits of Bearing capacity). But when i do only service load analysis without Earthquake load so everything is ok. . so Please guide me which load combination i have to take for it . Kindly if possible give proper reference of any standard document. your early response will be highly appreciated.  Thanks
Good question/observation.
That is the reason codes changed the foundation design from service to ultimate.
1. For your case; make sure there is no tension under service load combinations. Or remove it.
2. Make sure the compression is less than bearing capacity under service load combinations.
3. Once above two steps are done, and before proceeding to ultimate design of reinforcement, make sure that there is zero tension under ultimate load combinations, otherwise the ultimate design will be under-estimated.
Dear Rana.
Thanks for your kind response.
yet i have question .
i have applied Earthquake combination along with service loading.. now for Eq. in x direction with + ive all supports have compression or say upward reaction. but when EQ in x direction with -ive applied . there is tension occurring in one of the column support.. so what to do with it. i asked  my friend and he say just apply service loading without Earthquake so how i can do that because if Earthquake happen then ?? if you dont mind i will have to talk you on email or phone call ...
Edited by adilkhan
Yes Dear Rana.Thanks for your kindly. . Now i got it . Will you provide me any reference to it ? i mean ACI or ACSE where it is clearly mentioned . because my senior ask me to provide Reference to it also. Kindly guide me on this .
What reference anyone could ask for? This is common sense. Tell it to your senior (assuming you understood him as you said here).
