Design of Dome
civilengnr
Dear anyone,
  I am designing a dome with radius 40'. I have designed it manually (i.e amount of meridian and hoop stresses  ) but since the dimension is very large, i have difficulty in designing the circular beam under dome (their occurs very large bending moment). i had searched the forum but every attachment has been either removed or is no longer available. now i am trying to model and design it in Etabs. and i read the material on forum the method using extrude properties command, but what properties should be assigned and what results should i be looking for?
civilengnr,
There are various topics with very useful attachments and all the links are working. You need to be logged in to your account to download the attachments:
You can assign shell properties, see what stresses you get against applied loads and provide required reinforcement. This is the summary of dome design.
  On 5/29/2018 at 6:11 PM, UmarMakhzumi said:
civilengnr,
Salam
i have modeled the dome. now comes the reinforcement. in manual design there are only simple stresses (meridian and hoop) but in my model there are bending stresses too. Do i have to apply reinforcement for both B.M and these meridian and hoop stresses?
Also which moment (M11 & M22) or forces (F11 & F22) should be used for meridian reinforcement. and which are to be used for hoop reinforcement..
Thanks in advance
