Deflection
Hamza Ahmad
Aoa
 I have a question?  if I want to check deflection for beam manually so I have to consider it as T or Rectangular beam for deflection check OR first, I have to check whether beam act like T or rectangular beam (a<hf) ??
Thank you so much for your reply...i have few other questions??
1) Should we consider a wind load effects on a structure to be constructed on Hilly area(Daman-e-koh Islamabad) and it's just single story HALL (102' x 55' Approx) ??
2) In General notes of structure Fc' for beam and column might be given as 4000psi (both column and beam) or 3000psi for beam.  while designing in etabs should we take it less or not because taking it less will result in more conservative and uneconomical design but on another hand its also difficult to achieve 3000 psi...
Sir sir one question more..is it necessary to take stiffness modifiers ?? as I notice by not taking stiffness modifier will increase reinforcement in beam and decrease in Column ?? in my case I am working for single Story Hall (102'x55') ..
Sir, i have also taken the live load as 100 psf (ASCE table 4-1) And superimposed 60 psf ..
Need your guidance is i have taken loads correct .. beam as 14' apart, slab thickness = 8". Column dimension (30" circular column), Beam Depth 55"x18" (and sir did etabs includes slab thinkness in beam during analysis ) ??
