Concrete Cylindrical Stregnth
farhhhan
Although this forum discusses about very advanced level issues of  structure designing of concrete and steel. I have a very basic sort of question which i was unable to find in literature so any help from anyone will be highly appreciated. The misunderstanding in my mind is that when we test concrete cylinder in compression testing machine as per ASTM standards. The dimensions of cylinders are 1 foot height by 6" diameter. We use this concrete strength of concrete in designing of beam and designing of any structure of concrete regardless of stress/strain pattern. f'c used in designing formula is as per strength of cylinder of ASTM.
If we change the size of cylinder as we use 8" height and 4" diameter the strength of concrete cylinder increases a bit and it is further increased if we use cubes instead of cylinders. Some testing standards allow to use specimen other than ASTM. Conclusively, the strength of concrete is highly dependent upon the type and dimensions of concrete specimen. My questions are
1)- What will be f'of cylinders sizes other than ASTM sizes used in designing formulas?
2)- If ASTM cylinder size truly depicts the concrete actual strength in structure then is there any literature available on this or some research paper?
Let me explain my question in a different posture.. Suppose we have three bar sizes #8, #4 and # 11 for grade 60 steel. If we experiment over the Yielding strength, it will come out to be 60 ksi for all sizes and we use this strength in our design formulas and all. But in the case of concrete we use ASTM Standard cylindrical strength in all our design formulas, like strength of column is 0.85 x f'c  x a x b (let a and b be the column dimensions). Here f'will be 28 days cylindrical strength. But changing the cylinder dimensions will be change the strength of concrete specimen suppose we have standards of 6" cube, then strength will be different and using above formula for column will over estimate the columns nominal strength.
Does we have any reduction factors if we use different concrete specimen??
Does the ASTM Cylinder size truly depicts the actual strength of concrete in actual structure? If it do so then is there any research paper over it?
I believe strength formulas are calculated based on the standard cylinder strengths given in ACI. That's how you design it.
Now, if you want to test the concrete with whatever the dimensions or shape, it has nothing to do with actual building being constructed or the formulas used in the design.
Hi @farhhhan,
concrete as a material is heterogeneous. I have never used ACI but in the BS standards I use, a value of 0.67 f'ck  which converts the cubes strength to cylinder strength because the cylinder more closely predicts the strength of the concrete (0.85 is the ratio we use) and an additional factor is used to take into account the size effect since concrete strength varies with size (as you have stated) plus the rate of load since in the real world loading isn't added as quickly in the lab. Very many studies have been carried out and it was proposed to take only about 0.8 of cylinder strength to account for all this which gave 0.67 (0.85 x 0.8). you use 0.85 which relates to my 0.8 so I feel you are ok.
Edited by rutzilla
Regarding your questions, size and specimen affects are well known in research and remember there are no actual values that we are shooting here. We have strength reduction factors (based on probability etc) and if actual strength is higher than what would be for a specimen, so that is a good thing, no concerns there.
Here is another area where this thing happens a lot. If you take shear and 3-point flexural tests done during research on beams per ASTM specs, the specimen used are in no way reflective of actual beam sizes used. I don't remember exactly but you can use a small cross-section section size like 4" x6" for a beam per some ASTM test and get away with it.  I came across this during my masters lab. But the results are taken, factors applied to the results and used in engineering. The strength reduction factors used in shear strength formula (0.65 in Canadian code is reflective of that- big reduction).
So you have a valid point, but this is already addressed in one way or another. So to answer your question:
It would be different but you should stick with the one used as standard for reasons discussed above.
I am not aware of that but you can find this on the internet esp if you have access to research journals.
fc’ used in strength design is uniaxial strength of concrete. Compressive tests on concrete specimens (cylinder or prism) with L/D=>2.0  (length to diameter) closely resemble uniaxial condition in the central part.
Due to multiaxial stress conditions (i.e. lateral restraint at the top and bottom platens), compressive strength of standard cube specimens (150mmx150mmx150mm) will generally be higher (1.4 to 1.1 times) than standard cylinder specimens (150mm dia x 300mm height).
Depending on the maximum size of aggregate (1/3 diameter of mould), smaller size cylinders (100mm dia x 200mm height) are allowed for testing in various standards.  Compressive strength of specimens smaller than standard size will generally be higher.  For 100mmx200mm size cylinder no correction is required due to small variation in strength (4%).  This variation can be reduced by moulding 100mm diameter cylinder in two layer.
If L/D ratio of the tested cylindrical specimens is other than 2 then correction factor will be required.  Cylindrical specimens with L/D ratio less than 2 will show higher compressive strength.  Therefore, the correction factor will be smaller than 1.
In-situ strength are generally lesser than laboratory cylinder strength due to various reasons such as size, loading rate, curing method etc.  In-situ strength is generally taken as 0.9fc’.
In the design strength of 0.85fc’ the factor of 0.85 includes difference in insitu and cylinder strengths and the ratio to convert stress distribution to rectangular Whitney block.
In BS 8110 standard, design strength is taken a 0.67fcu.  The factor of 0.67 includes difference in insitu and cube strengths, difference in cylinder and cube strengths and the ratio to convert stress distribution to rectangular block.
For details on compressive strength testing you can refer to ASTM STP 169D Significance of tests and properties of concrete and concrete-making materials.
