Finding masonry wall stresses in Etabs.
rutzilla
Hello Everyone,
Once a masonry wall is modeled in etabs, how can I see the stresses in the wall? I modeled a sample masonry wall of 5 Mpa and wanted to know when the wall in story 1 fails (compressive strength of 5 Mpa is exceeded) after adding one floor after another.
On 8/28/2018 at 11:34 PM, rutzilla said:
@Ayesha yes i did. I used 'thin shell' option. I wanted to know what stresses I'm supposed to look at to know whether the 5 Mpa is passed.
This has been discussed at lengths in other topics. Kindly see the following:
On 9/6/2018 at 1:15 AM, Suarez said:
I think (I may be wrong!) masonry walls should be analyzed as "Strut & Tie Model" not as a shell element.
Good point. My take is that Strut and Tie would be more applicable if we are analyzing infill walls. For pure masonry shear walls, shell should be okay as we use them for concrete shear walls too. Similar behaviour in analysis.
