Dyck Memorial Bridge Bridge Collapse
Bridge that collapsed six hours after opening was built without geotech investigation of riverbed: Reeve
Geotechnical investigation not done, Reeve said
Hicks said a geotechnical study of the riverbed wasn't done before the bridge was built. Inertia, the engineering company for the project, declined to answer media questions and referred calls to the RM.
Initially, Hicks told CBC the geotech work wasn't done because it's not possible to do that work under the river.
"You can't drill through water," he said. "You can't do it. You can't take underground samples."
He said people in the industry he spoke to told him standard practice was to drill holes on each shore and assume the soil under the river would be the same.
"All the bridge people that we've talked to since this has happened indicate that's what they do," said Hicks. He said he is not sure if Inertia did drill holes on the shore when building the Dyck Memorial bridge.
Paul Gauvreau, a bridge-building expert from the University of Toronto, disputes Hicks's claim.
"I think it's irregular that a proper geotechnical program wasn't done for the piers in the water," said Gauvreau, an engineering professor at the U of T. "And it is not correct to say that it can't be done in a river. It's done all the time."
He said that is even the case for a small bridge like the one in the RM of Clayton.
"Perhaps for smaller bridges you can get by with a less extensive geotechnical program, but generally speaking you're going to have at least one test hole at the location of every pier including piers in the water," he said.
Geotechnical investigation too expensive, says Reeve
Later in the interview, Hicks acknowledged that perhaps drilling can be done under the riverbed, but said it would be costly.
"Well the fact of the matter is we don't have a heck of a lot of money," said Hicks.
According to Sasktenders, the bridge contract was worth $325,000. Hicks said it's difficult to justify a huge budget for this bridge, which he estimated would have about 1,000 vehicles crossing it annually.
Gauvreau also disputed Hick's claim about the cost of this work.
"A geotechnical investigation relative to the cost to build a bridge is not that expensive. It's being sort of penny-wise and pound-foolish by not doing the geotechnical investigation," he said.
Furthermore, he said making this sort of decision based on cost is not appropriate.
"It's not an insignificant cost but the point is that's not a cost that you can shave," Gauvreau said.
Read more:
https://www.cbc.ca/news/canada/saskatchewan/bridge-that-collapsed-six-hours-after-opening-was-built-without-geotech-investigation-of-riverbed-reeve-1.4829890
